Dodgy trade pictures for your amusement! - 1 Million Views! | Page 72 | on ElectriciansForums
Darkwood
Supposed to be changing some fittings and installing an outdoor lighting circuit. But I came across this gem of an install today.
32A mcb taken straight off the main switch. No rcd protection. (Rest of circuits RCD protected)
Then a what looks like a 6mm Earth taped up as BLUE (jesus christ) and terminated into load side of mcb. This loops round into the pictured connector. Which has the kitchen ringmain, 1st and 2nd floor lighting circuits coupled all in together.
I found A LOT more 'fun' things aswell.
Customer assured me he moved in a year ago and all paperwork was up to scratch. Yet to see any...
So not only did they run out of brown single or twin and earth, they also ran out of brown sleeve! Still at least we knew what they meant!(even if they didn't)!!!
Not just that. I don't understand the mentality. There was not a space issue. One side of the board was virtually empty. Loads of spare ways!
My first thought was it was done by a DIY or chancer, trying to solve a neutral-earth fault. But it wasn't. God knows....
Oh sorry for the double post, but this thread has reminded me of my best find this year so far. About two months ago, doing some remedial work on a HMO.
7.5Kw Shower in fed in 6mm. But nothing at the board. Switch off the the ring main. Oh and look what switched off with it.
Back to back to the shower was this little delight....
I stil have no idea how they managed to fit a 6mm and 2x 2.5mms into those terminals.
The run of 6mm must of only been a metre and a half. The students there said they'd never had any problems whatsoever.
