Remove outlet within a GFCI circuit | on ElectriciansForums
Discuss Remove outlet within a GFCI circuit in the USA Electrical Forum area at ElectriciansForums.net
Maureen
Port Charlotte, FL
I apologize for the repeat. I lost the responses.
I need to remove an outlet in a gfci circuit to remove a cabinet.
I need to know what to do with the wires.
Thanks!
[ElectriciansForums.net] Remove outlet within a GFCI circuit
Thanks!
Just make sure that the power is off and take the wires loose and just put wire nuts on it. Make sure that you identify the live wire which will be hooked up to the line side of the GFCI so if or when you reinstall it you will know how to wire it back up correctly.
Wire nut each wire separately? The rest of the circuit won't be affected?
Reply to Remove outlet within a GFCI circuit in the USA Electrical Forum area at ElectriciansForums.net
I’m trying to replace a gfci outlet which does not work in a bathroom at a relatives house which was just purchased. Circuit checker shows no...
It would be more helpful if you could tell us what the HP is on the motor since it will have to be considered a continuous duty motor since it...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
