prefer the makita gear.mainly because you can buy any spare part if needed.
Can't this be done with dewalt? Apart from the chucks, what else is serviceable?
Discuss Good drill and driver in the Electrical Tools and Products area at ElectriciansForums.net
yes you do. to sweep up the debris after drilling. .You can buy Dewalt parts online, even eBay. Though with brushless you don't need brushes.
I also have this. The handle is bloody enormous. It's got serious torque (125Nm I think), but it's also nowhere near as much RPM as the top end Dewalt 3 speed one, which is seriously quick! I like it a lot too but it's a tad on the heavy side compared to other makesI recently treated myself to a Makita DHP 481 and am mighty impressed with my purchase. This is one very, very powerful combi drill indeed! If you splash-out an extra £44.00 you can fit it with a 5.0 ah battery and also acquire a charger. I can't recommend this drill highly enough. It's the best I've ever owned!
Other than a lazer level I have no Dewalt battery tools, all my kit is Makita 18v.
My Core drill is Makita, you are a traitor
With the exceptions of my 36 volt SDS Plus, my 230 volt wall chaser, and my 230 volt diamond core drill, the remainder of my kit is Makita 18 volt, all of which are powered by 5.0ah batteries that last for ages between charges. I've used Makita products for the last 15 years and will continue to do so until I retire.
Which De Walt laser do you use? I'm looking to upgrade from my present laser which is rather basic and often inadequate. I have read good reports about the De Walt range and would definitely consider investing in one should they fare better than the Makita range.
I've the DW087k. It's good for what I use it for (mainly domestic/small commercial). Back when I bought it (around 2010) it's what all the shop fitting dry liners had. Time has moved on and things have evolved...if mine needed replaced and I was on a budget I'd get the DW088k but if a little more flush I'd get the green laser version which they all seem to use now, much much brighter...
Dewalt DW088CG Green Cross Line Laser Level Self Levelling – Includes Bracket and Hard Case « Buyaparcel - https://www.buyaparcel.com/p/dewalt-dw088cg-green-cross-line-laser-level-self-levelling-includes-bracket-and-hard-case/?gclid=Cj0KCQjw8b_MBRDcARIsAKJE7lkbNcvQO7_ziVCqiqwxs37FxC6LsY4VEKaIftz--eC1CgZ7-CaNW74aAoH4EALw_wcB
What laser do you have atm?
That looks like a very nice piece of kit indeed and I will certainly consider it as a leading contender when I'm ready to make my purchase. I particularly liked the bright green beam. One of the complaints that I have with my present laser is that the red beam is often difficult to see, particularly when used in a bright environment. I also liked the magnetic clamp feature and the ability of the laser to be used in conjunction with a tripod. The laser detector feature is useful too. Thanks for the heads-up.
And what are you using it for?
Mine is mainly for kitchens which I do a lot of, and downlights. If ceiling is to be plastered I use a chalk line for downlights instead.
Looks a handy bit of kit that too.I have the 3 line laser, is it DW89k or something like that. Puts 2 lasers on the ceiling. Handy for downlights. The green version is around £100+ more, but only benefits outside or in very bright rooms.
The red is virtually invisible outdoors whereas the green is designed for outdoors.
I have a couple of erbauer tools also. They are not as good as milwaukee in my eyes but good value for money. Grinder and recip saw have been abused and still going strongWas using Makita until they stole my whole kit.
Multi tool, sds, combi drill and impact driver
It would have cost me more buying the whole set as i build it up slowly with time
Had no option but buy Erbauer set
They haven't dissapointed me and the good thing no one is interested in nicking or pinching them
Added bonus.
But they ain't a makita or dewalt or Milwaukee
Quality, service are different but does the job.
Reply to Good drill and driver in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
