I don't really know the Erbauer range, although I do have one of their mains planers, which has been OK for the small amount of use I have for it. I get the impression that they're really a Screwfix own brand.For this range specifically or for erbauer overall?
The XR range is the Dewalt stuff.
I have the combi drill, impact, sds, multi tool, circular saw, angle drill and led floodlight, 2x5.0ah 18v batteries and 4x6.0ah 18v/2.0ah 54v flexvolt batteries.
All my cordless kit is Makita...the trouble with them is there is quite a range to choose from...
http://www.makitauk.com/products/cordless-tools/combi-drills/18v-combi-drills.html
Just the 10 combi drills in the 18v range
I'm guessing with that level of equipment you are happy with the quality/workmanship and feel?
That's part of the problem. Iv done some google searching for "makita brushless 18v drill" and there's loads. I don't know which range to choose from lol
prefer the makita gear.mainly because you can buy any spare part if needed.Iv been doing some research and Iv narrowed it down to dewalt and Makita. This is purely based on reviews/features/ other equipment within the range and also resale value if I choose to change in the future.
I keep going back to dewalt. That's based on the fact I prefer the look, they are generally slightly cheaper and the reviews and tests outweigh the makita's slightly.
yes you do. to sweep up the debris after drilling.You can buy Dewalt parts online, even eBay. Though with brushless you don't need brushes.
I also have this. The handle is bloody enormous. It's got serious torque (125Nm I think), but it's also nowhere near as much RPM as the top end Dewalt 3 speed one, which is seriously quick! I like it a lot too but it's a tad on the heavy side compared to other makesI recently treated myself to a Makita DHP 481 and am mighty impressed with my purchase. This is one very, very powerful combi drill indeed! If you splash-out an extra £44.00 you can fit it with a 5.0 ah battery and also acquire a charger. I can't recommend this drill highly enough. It's the best I've ever owned!
Other than a lazer level I have no Dewalt battery tools, all my kit is Makita 18v.
My Core drill is Makita, you are a traitor
With the exceptions of my 36 volt SDS Plus, my 230 volt wall chaser, and my 230 volt diamond core drill, the remainder of my kit is Makita 18 volt, all of which are powered by 5.0ah batteries that last for ages between charges. I've used Makita products for the last 15 years and will continue to do so until I retire.
Which De Walt laser do you use? I'm looking to upgrade from my present laser which is rather basic and often inadequate. I have read good reports about the De Walt range and would definitely consider investing in one should they fare better than the Makita range.
I've the DW087k. It's good for what I use it for (mainly domestic/small commercial). Back when I bought it (around 2010) it's what all the shop fitting dry liners had. Time has moved on and things have evolved...if mine needed replaced and I was on a budget I'd get the DW088k but if a little more flush I'd get the green laser version which they all seem to use now, much much brighter...
Dewalt DW088CG Green Cross Line Laser Level Self Levelling – Includes Bracket and Hard Case « Buyaparcel - https://www.buyaparcel.com/p/dewalt-dw088cg-green-cross-line-laser-level-self-levelling-includes-bracket-and-hard-case/?gclid=Cj0KCQjw8b_MBRDcARIsAKJE7lkbNcvQO7_ziVCqiqwxs37FxC6LsY4VEKaIftz--eC1CgZ7-CaNW74aAoH4EALw_wcB
What laser do you have atm?
That looks like a very nice piece of kit indeed and I will certainly consider it as a leading contender when I'm ready to make my purchase. I particularly liked the bright green beam. One of the complaints that I have with my present laser is that the red beam is often difficult to see, particularly when used in a bright environment. I also liked the magnetic clamp feature and the ability of the laser to be used in conjunction with a tripod. The laser detector feature is useful too. Thanks for the heads-up.
And what are you using it for?
Mine is mainly for kitchens which I do a lot of, and downlights. If ceiling is to be plastered I use a chalk line for downlights instead.
Looks a handy bit of kit that too.I have the 3 line laser, is it DW89k or something like that. Puts 2 lasers on the ceiling. Handy for downlights. The green version is around £100+ more, but only benefits outside or in very bright rooms.
The red is virtually invisible outdoors whereas the green is designed for outdoors.
I have a couple of erbauer tools also. They are not as good as milwaukee in my eyes but good value for money. Grinder and recip saw have been abused and still going strongWas using Makita until they stole my whole kit.
Multi tool, sds, combi drill and impact driver
It would have cost me more buying the whole set as i build it up slowly with time
Had no option but buy Erbauer set
They haven't dissapointed me and the good thing no one is interested in nicking or pinching them
Added bonus.
But they ain't a makita or dewalt or Milwaukee
Quality, service are different but does the job.
Almost 4 years.
Some do!Things change ..but tools LAST ?
