Extending shower cable | on ElectriciansForums
Discuss Extending shower cable in the UK Electrical Forum area at ElectriciansForums.net
Solihull
Hi people, I have a cable that comes up into the shower. Now as it stands the old sparkie extended the cable by using connector strips then putting tape around this. He left the wire outside Of the wall which I know is dangerous. What is the best way you would fix this situation as I would be sinking the wire into the wall?
Does the cable come from above?
Replace the cable to the shower pull cord, if there is one? He didn't come direct from the DB did he? Is
[ElectriciansForums.net] Extending shower cable
Reply to Extending shower cable in the UK Electrical Forum area at ElectriciansForums.net
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
Better off with the click prw213 as it has twin screw termination.
