Extending shower cable | Page 2 | on ElectriciansForums
Discuss Extending shower cable in the UK Electrical Forum area at ElectriciansForums.net
Solihull
Hi people, I have a cable that comes up into the shower. Now as it stands the old sparkie extended the cable by using connector strips then putting tape around this. He left the wire outside Of the wall which I know is dangerous. What is the best way you would fix this situation as I would be sinking the wire into the wall?
Reply to Extending shower cable in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
But why do they want a CU? That won't give them any more available power than they currently have. As it is a 2.5mm SWA cable it is presumably a...
davesparks
"Value engineering."
4K
Oh definitely, the amount of tails that I come across in consumer units barely nipped up is staggering, I always tighten them, wait a minute, give...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
