Dodgy trade pictures for your amusement! - 1 Million Views! | Page 91 | on ElectriciansForums
Darkwood
I was lucky enough to cut a square in the ceiling at the opposite side of the kitchen. Grabbed the cable and pulled it back. (Closer to the CU). In essence making it longer so I could chop off the damaged part.
Tel... I am unaware of a MF joint box for 6mm. The J803 boxes accept up to 4mm. If someone could recommend a product that would be great.
James
after getting several sub 1 ohm L-e readings around the circuit, finally ame to end of line and got 0.07 ohms. so i says to Simon " fault is approx 2m away. when we cut into the board and pulled the cable out, it was 1. 8m from the end.
Nice to see the thoeries work eh!
