Discuss Live cable taken straight off busbar..Reg no. required. in the UK Electrical Forum area at ElectriciansForums.net
I agree but I would not like to make a judgement on a non recommended ad hoc connection that it does not pose a danger as you have nothing to gauge it against. It is difficult to see but the only way that lug can be fitting flat to the busbar is if it has broken the plastic busbar support which it looks like it has.There's a difference between finding something acceptable to do and finding an existing bodge dangerous enough to recommend immediate disconnection.
That’s ok then.Drill a hole elsewhere on the busbar !!
But yes that is a busbar support with the bolt captive in the bakelite so you could never tighten it too much.
No that board never had busbar covers QUOTE]
Mystic Meg?
Hopefully there isn't an MCB with more than one cable connected as well or you'll have the place evacuatedI will Code it no matter where it is.
You could gauge it by the fact that it has almost certainly been there for a considerable time, (red cable), and seems not to have spontaneously combusted yet.I agree but I would not like to make a judgement on a non recommended ad hoc connection that it does not pose a danger as you have nothing to gauge it against. It is difficult to see but the only way that lug can be fitting flat to the busbar is if it has broken the plastic busbar support which it looks like it has.
If this was a domestic board and the connection was on the busbar you would all code it on an EICR .
Oops - missed thatIf you expand the photo, you can see that the nut and bolt is connecting two lengths of busbar.
I would call in something else.I wouldn't do it but can we just call it unorthadox?
I wonder if he would call this the same?I would call in something else.
Would you care to quote the regulation you are basing that on?
Reply to Live cable taken straight off busbar..Reg no. required. in the UK Electrical Forum area at ElectriciansForums.net
