Live cable taken straight off busbar..Reg no. required. | Page 3 | on ElectriciansForums
Discuss Live cable taken straight off busbar..Reg no. required. in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Evening...Can anyone tell me which reg this breaks??
It feeds a switched fuse.
[ElectriciansForums.net] Live cable taken straight off busbar..Reg no. required.
I agree but I would not like to make a judgement on a non recommended ad hoc connection that it does not pose a danger as you have nothing to gauge it against. It is difficult to see but the only way that lug can be fitting flat to the busbar is if it has broken the plastic busbar support which it looks like it has.
You could gauge it by the fact that it has almost certainly been there for a considerable time, (red cable), and seems not to have spontaneously combusted yet.
If the bolt just screws into the bakelite I'm not sure you could reliably torque it. So I'm back with the thought that it's a locating bolt, not a termination point so it will not be designed for this use.
Reply to Live cable taken straight off busbar..Reg no. required. in the UK Electrical Forum area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
