Help needed with hob fault | on ElectriciansForums
Discuss Help needed with hob fault in the UK Electrical Forum area at ElectriciansForums.net
Just been to look at a hob that has been getting hot above the electrical / gas connections. I was unfortunately unable to locate the source of the problem.
No visible damage to cables,
Zs fine,
RCD checked out fine,
IR >999 @500v,
And is still fully operational.
I’m Baffled, any ideas?
[ElectriciansForums.net] Help needed with hob fault
Did it actually get hot whilst you were there?
There looks to have been a sticker in that location... could have burned by something placed on it???
I wouldn't have thought that supply (assuming it's fused properly) would be able to deliver enough power to cause that.
Zs fine,
IR >999 @500v,
Heat rises, hence anything above the heat source will receive a rise in temperature and get hot, simple physics in essence.
Yeah, they are going to buy a new one anyway, but I don’t like leaving without finding the cause. No damage anywhere other than under the sticker - I have a video of my nephew pouring a little water on it - and it boiled?
I know you probably won't be able to answer these...
With the power off did it cool down?
With the gas off did it cool down? It's more over the gas inlet... is it possible there is a leak that has been ignited and is slowly cooking the cooker from the inside???
Really grasping for ideas I know :D
No sign of thermal damage underneath. I was also clutching at straws, just as I was leaving I remembered the oven had been removed and had a metal case that could’ve been touching the gas pipe, so I checked that too - all fine.
The picture doesn’t show the mark very well, but it looks like an arc welder has been used on the casing.
I was unable to replicate the fault - I turned the gas back on, used all the hobs. Installed the oven and put that on too.
Water bonded, gas bonded - all tests were as you’d expect them to be?
They turned the gas and electricity off, and yes it cooled down - just cannot get it to heat up again now.
On a gas hob really?
It looks like a burnt sticker to me. Never the less, I've never seen a loose connection burn through stainless steel from the connection block below.
I’ve seen similar marks before but there has always been a logical explanation.
I was beginning to think of an external issue, but nothing else has been damaged - usually TV’s, boilers, programmers, etc are damaged too.
Reply to Help needed with hob fault in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
