Megger mft1741 tested today | on ElectriciansForums
Discuss Megger mft1741 tested today in the Electrical Tools and Products area at ElectriciansForums.net
trypod
Essex
Good points:
Loop test Hi & low Current only 0.02 difference
RCD tests very fast
Bad point : no earth spike kit with meter
Firmware 3.0
Could be the best Megger so far!
Thinking about buying one of these 1741's on Monday. First multifunction tester for me, but used older meggers in college so am sticking with the brand. Would you say its worth the extra price for the 1741 over the 1731 / 1721
For a princely sum of ÂŁ1050 (inc VAT) I would expect it to do everything, not most things...
[ElectriciansForums.net] Megger mft1741 tested today
So it's a separate model,but just has two extra non-life changing functions?
Loop test confidence meter,hey?
I'm going to wait for the model that has,a continuity hopefulness scale,and IR expectancy indicator :)
The 1700 series is much much quicker on RCD tests than the 1500s.
My only little gripe is I got used to the negative values with the continuity setting on my old 1552, whereas with the 1700s it just shows the less than symbol for negative values, which means more zeroing of the leads all the time.
Reply to Megger mft1741 tested today in the Electrical Tools and Products area at ElectriciansForums.net
Megger 15 series in my opinion are the best. Had a few 17 series that have put out err 23 codes. This is s an internal clock component issue...
Darren dazz
That is very cool. It would be the end user software that would make that the absolute king.
    • Winner
    • Informative
