Darkwood
Too small once you apply grouping factors.
Expand on your grouping factor, why would you be applying it here?
Discuss Looks a squeeze, 240 swa thoughts. in the Talk Electrician area at ElectriciansForums.net
Ccc for tri rated are generally for a single conductor in free space, apply six of them and assuming they will not be separated in free space grouping factors should be applied.Expand on your grouping factor, why would you be applying it here?
Reply to Looks a squeeze, 240 swa thoughts. in the Talk Electrician area at ElectriciansForums.net
