You should not need any more cable! In anycase, that cable is 2.5mm csa and way too big and unwieldy for lighting applications. Normally we use 1.0mm.
The wires to the switch should be in pairs, blue and brown.
First of all, the two wires that used to go to the switch for the downlights. I hope you know which two they were?
Put those two wires in separate bits of the choc block, to insulate them in case they are still live.
Then you'll have two pairs of brown and blue wires. For each pair.
Put brown in the terminal marked COM and its corresponding blue into thje terminal marked L1.
And as noted above, the eartyh wires need sleeveing in yellow and green sleeve and connecting to the earth terminal on the metal back box.
You should not need to do anything else.
