Hi messed up confused. Changing 3 way switch to 2 way switch | Page 2 | on ElectriciansForums
Discuss Hi messed up confused. Changing 3 way switch to 2 way switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The problem here is we do not know the original set up but I can only guess it was three plate switching because there were only three cables at the switch. Next problem we do not know how you have altered the wiring and whether the this type of switching is still in situ. We can often tell people what wires go where but sometimes as in your case it is not wise for us to guess and even if you manage to get the correct sequence your connections are so poor you are asking for trouble. So I will say it, employ the services of an electrician.
If you had got an electrician in before you disconnected everything it would have taken him/her less than 15 mins to sort.
Now he/she will have to identify all the cables before proceeding. Much longer to sort. More expensive.
Reply to Hi messed up confused. Changing 3 way switch to 2 way switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Thanks again for your help, now solved đź‘Ť
