Federal 3871 “type” required for EICR | on ElectriciansForums
Discuss Federal 3871 “type” required for EICR in the Talk Electrician area at ElectriciansForums.net
Midlands
Hi does anyone know the type of the Federal “brown” 3871 breakers? The 3 poles have type 4 on them but nothing on the single poles? If they were type 4 the max zs of most circuits wont comply following our EICR.
Many thanks
How easy will they be to find??
Impossible now as Federal Electric are no more. There are many internet Tables you can look at as per #6 but these can only be taken at face value. Merlin Gerin, Federal Electric, Square D and Dorman Smith were the most common producers and all quote variable maximum values of Zs so one Table does not cover all brands. Manufacturers Tables also quote 0.4sec and 5sec disconnection times. The attached fax came from Federal Electric many years ago, I have overwritten so it is legible.[ElectriciansForums.net] Federal 3871 “type” required for EICR
Impossible now as Federal Electric are no more. There are many internet Tables you can look at as per #6 but these can only be taken at face value. Merlin Gerin, Federal Electric, Square D and Dorman Smith were the most common producers and all quote variable maximum values of Zs so one Table does not cover all brands. Manufacturers Tables also quote 0.4sec and 5sec disconnection times. The attached fax came from Federal Electric many years ago, I have overwritten so it is legible.View attachment 42774
Thats brill thank you very much for taking the time to assist!
Reply to Federal 3871 “type” required for EICR in the Talk Electrician area at ElectriciansForums.net
He only posted the one message then never came back.
This fella puts his face to it about halfway through, he has an opinion on the very subject.
4K
