Impossible now as Federal Electric are no more. There are many internet Tables you can look at as per #6 but these can only be taken at face value. Merlin Gerin, Federal Electric, Square D and Dorman Smith were the most common producers and all quote variable maximum values of Zs so one Table does not cover all brands. Manufacturers Tables also quote 0.4sec and 5sec disconnection times. The attached fax came from Federal Electric many years ago, I have overwritten so it is legible.How easy will they be to find??
file:///C:/Users/tel/Downloads/Zesses-sheets.pdf
Impossible now as Federal Electric are no more. There are many internet Tables you can look at as per #6 but these can only be taken at face value. Merlin Gerin, Federal Electric, Square D and Dorman Smith were the most common producers and all quote variable maximum values of Zs so one Table does not cover all brands. Manufacturers Tables also quote 0.4sec and 5sec disconnection times. The attached fax came from Federal Electric many years ago, I have overwritten so it is legible.View attachment 42774
I must warn you that sheet is 25 odd years old but it is from the horses mouth.
As I said those Tables are 25 plus years old.Don't forget that all the max Zs was adjusted in past editions of BS7671 for 230v and Cmin so values may have to be adjusted.
Hi does anyone know the type of the Federal “brown” 3871 breakers? The 3 poles have type 4 on them but nothing on the single poles? If they were type 4 the max zs of most circuits wont comply following our EICR.
Many thanks
If that was true I would have thought they would have been forced to stop selling them and we would have had it all over the trade press.It’s worth bearing in mind that Federal Electric went under because they fraudulently falsified test results of their MCB’s. There never was a product recall because it was deemed too expensive and it was cheaper to settle any claims through the courts. So it might be prudent to get rid of the fire starters while you have the chance.![]()
I don't understand they don't meet maximum efli values.They already don’t meet the maximum earth loop impedance allowed and under the 18th Edition will do so even less. He could also just note the safety implications in the recommendation section of the E.I.C.R. and let the client make up their own mind. It’s all about risk management. I personally have never seen a Federal Electric breaker burned out above 32A. They seem to fair better at higher ratings.
No they have never been listed due to their variable characteristics.Was there not the tables in the regs books in the 15th or before for max Zs for BS3871 circuit breakers?
Indeed they were!Well your values must have been well below those on the Federal sheet I posted.
Is that all BS3871 MCB's or just the Federal ones?No they have never been listed due to their variable characteristics.
All BS3871 Type 4 devices. Type 1, 2 and 3 were always included until superseded by EN60898.Is that all BS3871 MCB's or just the Federal ones?
Thanks for enlightening me on that westward as I was thinking to myself there are tables that include max Zs for BS3871 devices but does not include type 4.All BS3871 Type 4 devices. Type 1, 2 and 3 were always included until superseded by EN60898.
