3Ph sub-mains supplied via 5-core NYY, not SWA. OK or not? | on ElectriciansForums
Discuss 3Ph sub-mains supplied via 5-core NYY, not SWA. OK or not? in the Commercial Electrical Advice area at ElectriciansForums.net
Mark42
Patron
UK
Good morning
I need to fit a new 3 phase dis board in an annexe I'm building at my own house.
Usually I'd use SWA, or singles in conduit/trunking, but as the run is all in loft space and not liable to physical damage (no rodents), I'm thinking of using surface-clipped 5-core 16mm NYY instead, especially as there are some tight-ish turns, and space in the board it's coming from is also tight.
I can think of no technical reason why this is not OK. Possibly it's routine?
Any comments?
Cheers
Mark
[ElectriciansForums.net] 3Ph sub-mains supplied via 5-core NYY, not SWA. OK or not?
Is this new CU an addition to the existing house CU?
Why 16mm?
Why 16mm?
Because NYY's not easy to find in 25mm :)
New self-build extension which is eventually for holiday rental (It's my retirement fund!)
Fed from the main DB which is 100A x 3 in 25mm.
There's no reason not to allow for future expansion in the annexe (ie do it once!) and I want to add a Tesla charger 3 x 16A or 3 x 32A to encourage the right kind of rental client :)
4c 25mm HO7 and a 16mm GY would have been my first look.
NYY I think is always solid core.
I was thinking h07rn as well, but why not 5 core?
4c + G/Y is just cheaper and also if he's got some tight turns then it's more flexible /sharper radius too. Also makes it easier (smaller) to gland into a panel if space is tight.
Yeah, it'd take a 50mm stuffing gland for 5 core. I'm using a lot of it recently.
Thanks for the ideas.
BTW, I was joking about 25mm as I thought another poster was implying 16 was too big for a small annexe! It is only a 10m run, and will have a 32 or 40A TP MCB.
I hadn't considered H07RN. If as SuffolkSpark says, 16mm NYY might be solid (really?!) that's no good. I'm going to order 1m to check.
The thing is, although I know rubber flex is totally fine, both from a technical and regulation perspective, I can easily imagine a future inspecting electrician saying that some cowboy has used FLEX (!) for a sub main rather than SWA, like you 'have to'. Can anyone here say that could never happen? :)
At least NYY looks like SWA.
Reply to 3Ph sub-mains supplied via 5-core NYY, not SWA. OK or not? in the Commercial Electrical Advice area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
