Induced Voltage LED / Steel Trunking | on ElectriciansForums
Discuss Induced Voltage LED / Steel Trunking in the Talk Electrician area at ElectriciansForums.net
Leicester
Just fitted some 10 Low Bay Led all wired in steel trunking. Have just noticed my volt stick light up on 3 cables that are not even connected to anything. Gets volt meter out and I've got 38v on it. Seems a hell of a lot. Anyone else found this with LED power supplies
Have you tried testing with an analogue volt meter?
I have no idea what one of those is, nor have I ever owned one :)
They are great. Just remove the 'test' component inside and the screw driver is really useful.
Right size for choc block, opening small tins of paint, removing screw cover caps, removing battery cover for kids toys.....
if these "dead"cables are running alongside "live" cables, then you will get phantom voltages present. as post #5.earth the buggers preferably at both ends , or remove.
Simply you have induced voltage from some of the cables in the conduit. The current in these cables induces a voltage to in those cables which are not connected.
When you connect a DMM across the spare cables and ground the impedance of the DMM (10Mohm or more !) is so high that it sees this induced voltage.
My back to back (MSc qualified) spent hours offshore chasing this phantom voltage on an MCC before he sent me an email in the office and I gave him the reasons.
For this same reason the Dutch regulations (NEN) only allow testing for dead with a dipole tester. This tester has a button which when pressed increases the current flow through the tester to 100 mA.
This is why I prefer to use the old square D type coil based voltage tester over a DMM for proving dead.
As per Davesparks the voltage you read could be anywhere between zero and 230 depending on the potentials of the connected cables that the floating cable is lying next to. The actual voltage is pretty meaningless because it's not part of a recognisable circuit. Testers with different impedances will give you different numbers, typically it will be somewhere between zero and 115.
The current that you can draw from it will be microamps which is why even a high voltage is unimportant. You can charge a balloon up to thousands of volts by rubbing it against your jumper, but the charge stored is so low you won't get a useful measurement with any normal instrument. Like the balloon, the floating cable is just a conductor with some stray capacitance to things nearby.
Reply to Induced Voltage LED / Steel Trunking in the Talk Electrician area at ElectriciansForums.net
G
We hope your partner hasn’t had a serious injury from this. Might be worth mentioning it to a doctor. The appliance looks fairly new, so is...
As above, check the whole cable run and look for damage or any junction boxes that might have trouble inside them. Water getting in is a common...
Thanks heaps for the input. This seems to be the approach we are gravitating towards. We've already got a plan for the wiring, and our...
Hello. This is such a noob question, but I'm struggling with something that seems like it should be fairly straightforward. I have numerous 24v...
Lighting transformers and old biscuit tins.
