Can I move the splitter box myself? | on ElectriciansForums
Discuss Can I move the splitter box myself? in the UK Electrical Forum area at ElectriciansForums.net
JohnHome
London
Hi,
I want to move the splitter box in my meter box to make room for a smart meter, which looks relatively straightforward. Should I do that myself (homeowner), or does it need a specialist? Is there any requirement regarding its location?
Cheers
[ElectriciansForums.net] Can I move the splitter box myself?
I would expect the meter fitters to move it, as the only way to isolate it is by pulling the main fuse, which they will be doing.
So, no… it’s not something you should do yourself.
Ps I have deleted the duplicate post….
Actually, cancel that. Someone else beat me to it
well I did mine myself, oops perhaps I should not have said that.
Perhaps not.
All very well being an experienced spark, knowing the risks and carefully removing cover, unscrew from the wall and relocate…..
But the cables here look too short to move anywhere, and a couple of them look very old.
If the supply company insist on you having a smart meter, they can do all the work to make it fit.
You really don’t need to have one, whatever they might say….
Reply to Can I move the splitter box myself? in the UK Electrical Forum area at ElectriciansForums.net
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
How many and what type of cables do you want to join, Chocbox is the last thing I would use.
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
yeah. i think so. Details here..... https://www.electriciansforums.net/threads/havent-seen-tel-for-a-month.210295/
