Using cpc as neutral | Page 4 | on ElectriciansForums
Discuss Using cpc as neutral in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The 5 core cables were coming from the controls downstairs, as already explained. As was the cpc contained within supply cable. I'll have to remember to ask the wholesaler for a 5 core which doesn't contain a green/yellow covered conductor next time.
You can get YY flex or 7 core flex.
I'm not sure the wholesaler has 7 core flex, needed some to wire up a Rayburn once and it was a nightmare to find. That was a few years ago mind. Not heard of YY flex, does it not have a green/yellow core? Anyway, I'm sure there's nothing wrong with using the cpc in a multicore flex as long as it's identified properly, and it's not specifically prohibited in 7671 like an un-insulated cpc is. I go to great lengths to ensure that identification stays put :)
It will be hard to find YY cable that doesn't have the below comment in their specs. All depends on what you are using the YY cable for.
[ElectriciansForums.net] Using cpc as neutral
I thought he was using it as control wiring?
Tell you the truth mate, after 77 posts I lost the will to live, as well as what he was using the cable for...:)
Ha ha
Came across this with the LIVES on an EICR last week - 1 x 3 wago later it was sorted
I've had that before - in the absence of a live loop they'd twisted the lives together and stuck a bit of sellotape over the copper. Every light fitting in the house was the same.
I'd only gone to put up a smoke detector.
Reply to Using cpc as neutral in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I hate it when a shed is TTd, why can they not be extended from the tn system? popcorn ready
I’m sure I’ve seen an LSF round cable used on sites before as well with an insulated earth. Not flex, something a bit more substantial but not FP...
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
The MCBs are branded Noark.
It's the same with any system, if you put poo in, you get poo out!
