Steel conduit - tips and tricks? | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Steel conduit - tips and tricks? in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
Hello!
Got a few jobs on the way that involve large amounts of conduit work. All surface mounted and will mostly be mounted externally around the building.
I was just wondering if anyone has any good tips, tricks or good points to think about when doing it to be quicker and more efficient. This includes tools or working methods.
Thanks all.
Plan your route carefully to reduce the amount of joins and bends you need and use manufactured joints where possible.
It's faster to bend than than cut several threads and screw stuff together, easier to draw the cables though too.
Always a prob going round external corner,outside,some take out the brick,others,end box,conduit into that,whatever.
Swan neck it if it's not appropriate to chip away at the corner of the wall.
Use spacer saddles,or hospital saddles to allow conduit entry into socket or equipment.
I hate to see sets going into equipment when not needed.
Also if the knockout is slightly to the front,drill another hole,this then takes the conduit straight into the fitting.
Use a bush spanner to tighten up.
Don't like drilling over a knockout, could cause the existing knockout to become detached, causing damage to the box, wish the disagree icon wasn't so confrontational.
[ElectriciansForums.net] Steel conduit - tips and tricks?
There you go,it’s so easy
Reply to Steel conduit - tips and tricks? in the UK Electrical Forum area at ElectriciansForums.net
As above make the correct sized entries. In those days two locknuts were fitted, internal and external and tightened on each other then a female...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Recommended Sponsor News
Hi everyone,
Glasgow
