Steel conduit - tips and tricks? | Page 4 | on ElectriciansForums
Discuss Steel conduit - tips and tricks? in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
Hello!
Got a few jobs on the way that involve large amounts of conduit work. All surface mounted and will mostly be mounted externally around the building.
I was just wondering if anyone has any good tips, tricks or good points to think about when doing it to be quicker and more efficient. This includes tools or working methods.
Thanks all.
One of my jobs....... drove me round the bend......
[ElectriciansForums.net] Steel conduit - tips and tricks?
I managed all those bends in one length of conduit, you should see my tray and trunking work..........
If you do a few loop in installs and you can get quite into it, I enjoy doing that. I did it on some sockets on the same job to demonstrate measuring the bends in one piece for an apprentice. And no I didn't do the wonky bit feeding the switch the other side of the wall. Of course I could have gone straight across, but there's no need to demonstrate that. Cables can be pulled in after plastering.
My OCD is getting the better of me ;o)))))))
The wonky one behind was already there from when the building was built. Any spacing issues on the front 2 are an illusion. :)
@freddo was there a reason not to go straight across? I'm trying to work out why you'd go up, do a double 90 and come straight back down insead of going sideways for a much easier and shorter run.
As I said it was for a demonstration, that and I didn't want to wreck the wall, the noggins were well nailed in with long ring shank nails.
I like that, why, because it is fully rewirable , don't see much of that these days.!!
Reply to Steel conduit - tips and tricks? in the UK Electrical Forum area at ElectriciansForums.net
As above make the correct sized entries. In those days two locknuts were fitted, internal and external and tightened on each other then a female...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
