Hi I'm new to this forum but am hoping for some advice on wiring for my garage.
Ive recently built a new garage at the bottom of the garden and have run 30m of 6mm swa from the house to a new consumer unit in the garage to power 2 florescent lights from a 6a MCB, a 13a socket from a 16a MCB and a 16a socket from a 20a MCB. Everything is correctly terminated and works properly.
However, I'd now like to add a switch to the lighting circuit rather than using the consumer unit to switch on and off. I have bought a 1 way outdoor switch for this circuit but believe I will need to add a ceiling rose/ junction box to avoid a short circuit. Please can someone look at my wiring diagram to let me know if they think it works. Is this the simplest option? Also would wiring like this pass regulations; I'm doing the work but will need this signed off by a spark when I'm finished.
Many thanks in advance.
Joe
Joe
