TJ, the OP did the entire installI know what you're saying, but he only asked about a light switch lol. Why do we have to consider his whole install and certification? Someone is gonna ask about him "exporting" something in a minute hahaha![]()
If some one will take the test and inspect on, if the OP is taking that tack the the Person that's going to do the testing should have been involved from the outset of the job.He's an adult and that's his decision what he chooses to do. The job may well be satisfactory. The spark who tests and inspects it will decide that.
Valid point Pete, if 3rd party should be inspected at each stage. But I'm guessing that it is all clipped direct surface etc. and all could be inspected in one visit.If some one will take the test and inspect on, if the OP is taking that tack the the Person that's going to do the testing should have been involved from the outset of the job.
Depends upon how it is installed.Tricky to do that with the submain ...
It's to power a single phase table saw. When I had this set up in my old garage it kept tripping on start up. I changed the MCB to a type C with higher amps to account for the surge when it starts up.Why a 20 amp MCB for a 16 amp socket?
Part P, inspection and testing?
Insurance not paying out ..............................
Could be a very expensive "saving" the OP is trying to make.
Yes! The garage cu has a 30mA RCD incomer and the 3 mcbs run off that. I've also added an rcbo to the consumer unit in the house and run the swa cable from thatIs anything 30mA RCD protected?
Maybe he should have stuck with his 'wiring diagram', then, instead of treating us to full details...….obviously milking info, I reckon.I know what you're saying, but he only asked about a light switch lol. Why do we have to consider his whole install and certification? Someone is gonna ask about him "exporting" something in a minute hahaha![]()
Purely to keep any moisture out. They are installed inside the garage but my sockets, switch and cu are all waterproof. OTT maybe but I'd rather play it safeOut of curiosity, why an outdoor switch? Why not just put a switch inside the garage?
Are there any extraneous conductive parts in your garage?
Also, as above, any RCD protection?
Don't fancy the export business these mid Brexit days, so I'm not too bothered there.![]()
