Bypassing main fuse. Anyone else seen this? | on ElectriciansForums
Discuss Bypassing main fuse. Anyone else seen this? in the UK Electrical Forum area at ElectriciansForums.net
LONDON (barnet)
Evening all,
I was doing an eicr in a flat today, it came to checking the main service fuse.
Fuse pulled I proceeded to undo the case to check the amperage and was a little shocked with seeing a metal bar essentially bypassing the fuse(pics attached).
After a little thought I guess there is another fuse down below removing the need for a second fuse.
Anyone else seen this before and know the name of the part used? Or is this a one off
[ElectriciansForums.net] Bypassing main fuse. Anyone else seen this?
Gonna report you if you send this highly informative thread off course:D
Sorry Sir, you're right Sir, won't happen again Sir, promise Sir
For any standard electrical work including EICRs: It should not be common practice, it is not required, it is illegal, it is dangerous, to pull the fuse.
In this case luckily he has not pulled the fuse as it is just a link!
Just as dangerous though.
Where there are two service heads in series on the single supply it is redundant to have a second fuse so a link is used instead at the downstream service head.
Evening all,
Oh dear oh dear.
So you’re a DIYer carrying out an eicr and you don’t even know what a red cutout link is???
Clearly you are not competent to carry out an EICR if you don’t know something as basic as this! If you don’t even know the difference between a fuse and a disconnect link do you know the difference between left and right?
Oh dear oh dear.
diplomatic as ever, dave. :D:D:D.
Just in case.................I was joking!
I've found 200 Amp fuse in the suppliers fuse holder in a domestic installation. Probably followed the logic of if a fuse blows fit a bigger one. Since both the EIC and EICR require one to state the type and rating of the fuse, how can you be sure it is as expected, without removing and opening the fuse holder ?
DNOs must vary on this. ENWL do not allow interference with main fuse by private electricians. Seals are there for a purpose
You are not authorised to work in the incoming mains, it is not part of the installation, and is not covered by BS 6761. You did of course re-seal it afterwards, and wore the correct ppe and worked to the relavent code of practice as issued by the DNO? Again it's a big joke to interfere with the supply equipment, but look out anyone who does a bit of wiring when they're not qualified. I suppose next you'll be in the sub-station checking the lv board out.
Bs6761 ?
Reply to Bypassing main fuse. Anyone else seen this? in the UK Electrical Forum area at ElectriciansForums.net
Maybe you could get the cut-out replaced and upgraded to PME. If so, Then you could turn it around to face to the outside wall and move the...
Aha, no wonder the 30-year warranty :( (just kidding)
10K
No sane person 'trusts' a Voltstick for anything, other than if it lights up when a circuit should be dead, it means that something is not as...
    • Informative
7K
I do to a degree, but without going to pedantic levels when it is clear what is meant.
4K
It's a pity that when the meters are read these days the only cause for alarm is when there's a couple of probes jammed into the meter tails...
10K
