New consumer unit, builder says upgrade supply | Page 2 | on ElectriciansForums
Discuss New consumer unit, builder says upgrade supply in the UK Electrical Forum area at ElectriciansForums.net
London
Hi
As part of a loft conversion to my 2 (now 3) floor flat in a Victorian Terraced house I have added about a dozen 2-gang sockets, a shaving socket, and about 16 downlights to my new floor, plus swapping four pendant lights for 16 downlights in the floor below.
An electrician was installing a new consumer unit today and then I got a call from the head builder who is not onsite. He told me the electrician is concerned that the main service feed coming into the fuse/meter is only 10mm across. The electrician has apparently wired and tested everything (even though he's left the ground floor lights not working) but says we can't turn on the power in the loft as he is not confident the consumer unit will not burn out or the RCDs will be constantly tripping as the mains service cable is too thin.
The head builder told me I will probably have to upgrade my supply. He started advising me to call The National Grid (I think he means UK power networks).
I checked the main feed wire and by my measurements it looks around 12mm across. My builder was saying it should be more like 35 mm across and they'd never seen this before.
I apologise for the lack of detail but that's literally all the information I have aside from two photos of the set-up which are attached.
The reason I am posting is this all seems very light on detail. For instance I would expect a bit more calculation and maybe some figures to justify why we need to shell out many thousands potentially to upgrade the supply. The same amount of people will be living in the house, there are just likely to be a few more lights on and maybe an extra device plugged in.
Could anyone offer any advice about this? Should I just accept it, should I ask UK Power Networks about it, or should I be asking for more detail about how he came to this conclusion (and if so, what?)? Do the photos suggest what we have is obviously wrong? Any pointers would be much appreciated
cheers,
Pariah66
We can’t really say if you need the supply from UKPN upgraded, as it’s unclear what the existing capacity is and what your needs are. But it’s likely. This should have been sorted before CU change.
The pyro is a mineral insulated cable with a copper armour, in my opinion the best and my all time favourite..
A competent electrician would be able to sort out the whole set up for you..
The dno would need to be on board though to facilitate the necessary work.
Also looks like the main fuse isn’t clamped..
Do you have a cat??
In answer to various questions (and thanks again to everyone)
- This is part of a loft conversion, the builder subcontracted the electrician.
- This electrician has done all the wiring for the conversion - plugs, lights for the loft floor, smoke alarms and lights in the middle floor.
- There is a problem with loudly buzzing dimmer lights
- I have almost paid the full fee to the builder. The rest of the work has been good with no major issues. This was supposed to be one of the final tasks.
- A part P cert has not yet been provided
- Yes I have two cats.
Obviously I am horrified to read all of this. I will speak to the builder tomorrow but I am wondering if I should get an electrician in to look at this independently.
so, have you received any paperwork (electrical certificate) for the electrical work?
Reply to New consumer unit, builder says upgrade supply in the UK Electrical Forum area at ElectriciansForums.net
Thanks DefyG. I am thinking along those lines insofar as I will ask the electrician to build the DB/CU (plastic if he is OK with that)...
