Cable entry question | on ElectriciansForums
Discuss Cable entry question in the Talk Electrician area at ElectriciansForums.net
Newcastle
Hi all,
I am installing a new 3 phase DB and 110V DB. The current installation needs new DBS due to thier age and condition.
The cables used are all singles and ran in galvanised steel trunking and I am not replacing the single cores used.
My question is, is it alright to cut out a section in the DB that sits directly against a cut out section on trunking and use grommet strip to put around the cut out edges of the both the DB and the trunking so the singles can pass through safely?
Might sound like a daft question but I’m typically using SWA and tray when doing these jobs so have never came across the correct way to allow cable entry between metal trunking and a metal dB, keeping within the regs for IP and protection of cabling.
Any help is appreciated, cheers.
Personally I would use conduit bushes, cut out holes in the trunking to match the DB and then connect the two using the bushes, but if there is a gaping hole in the trunking... maybe replace a short section of trunking???
Sometimes you struggle to but them up because of gland plate screws etc like you get on Hager boards. You would be best with a bit of Paxolin sheet.
I agree this would be the best way to do it, it’s definitely the way I would do it if I was doing a new installation (although I would just use SWA and tray if I were to do it from scratch). To make the job quicker though, would putting the two together and using the grommet strip as I described in the question be acceptable?
Cheers
The existing installation is in a workshop garage within a quarry, so the 3 ph+n board is for lights, heaters, compressors, welders etc.. and the 110v is for the 110v sockets around the workshop.
Ah OK thanks very much for the update, must be an interesting job you have there.
Cheers
Seems like you may be viewing the solution as a bit rough and it seems like that goes against your usual approach. Would I be right?
I guess the answer is yes I think it's acceptable, I can't think of any reason it wouldn't be, except maybe containment of a fire within the DB. Providing the required IP ratings are maintained then I don't see a problem with it, except that it's possibly a bit rough and ready.
As @Leesparkykent pointed out you may have an issue with the gland plate.
We only install Eaton and fit their trunking adaptor so only have to cut out trunking works as the same principle as Paxolin. If you use bushes and couplers use large and fit as many as you can for future usage.
Reply to Cable entry question in the Talk Electrician area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Ok I’ll try this when I’m down
