Discuss Hi all having problems with this heating system will hw stick on because of power on terminal? in the Central Heating Systems area at ElectriciansForums.net
Hi yes my grey has permanent live from ch sw and when valve opens it sends power threw orange to hw terminal where boiler cable is also connected
I need to keep boiler cable in hw terminal so I can have hw only
Thanks for the reply
Cheers lads but there is no valve on hw (if there was it would solve it)
There is no cylinder stat either
(Called out just to put room stat on system)
Need hw only for summer when room stat isn't calling for heat
Thanks for input
Hot water is pumped aswell
Pump is in garage beside boiler
One cable feeding both
Is it ok to have power at hw terminal when hw switch is in off position?
Reply to Hi all having problems with this heating system will hw stick on because of power on terminal? in the Central Heating Systems area at ElectriciansForums.net
