Guest viewing is limited
John J
Trainee
So I’ve recently started my level 3 course and I’m doing electrical system designs the one with the hotel extension and pool and cafe block I’ve done question 1 but stuck on all of question 2 some guidance would be appreciated thanks.
Don't treat the question as a whole, break it down into its individual parts.
So for part A search online for luminaires and select ones that fill the criteria in the question.
For example 600x600mm LED panel lights 40w rating 4000K colour. Some units will be fitted with 3 hour emergency backup units to comply with emergency lighting regulations.
Units will have to have a suitable IP rating to use within the pool area, refer to section 7 of BS7671 for specific IP ratings in pool areas etc etc.
Upvote 0
Hi John,
I'm currently doing the same project.
The hotel rooms are like premier inns rooms. sockets either side of beds, 2 double socket on table for tv, kettle etc & socket by the sofa, heater fcu by the door & towel rail fcu outside of the bathroom.
CU in each room by the door.
when i get back home i'll convert my visio file to pdf & pm you so you can take a look.
maybe we can buddy up on this & throw ideas about?
Michael
Upvote 0
For a further hint:
I used to Inspect hotels, each floor had a distribution board supplying small (4 or 6 way) boards in each room. Maybe a power cct, lights, shower etc ...
Upvote 0
Hi John,
Michael
Do they have consumer units in each room?
Upvote 1
John J
Trainee
Liverpool
HELP PLEASE!!! 2365/615 electrical system designs
Electrician Courses : Electrical Quals
John J,
DPG,
Electrical Courses
