Cat 6 connections by a sparky | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Cat 6 connections by a sparky in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Had to cable some cat 6 cabling,while putting in ours,usual thing.
Just use what you have,which was external cat 6.
Can you 2nd fix them too.
Bit of a nightmare really,with my glasses on it was hard to see connections,also in awkward places to connect.
Also the quality of these data points can be pretty rubbish,tip ,buy the best,with cable tie & deeper connection.
Did it all,then one didn’t get internet,it was the one in the middle of a cupboard,awkward or what,all working now.
Is it that when electricians do this sort of work do we get a bit panicky.
The unknown ?
I took the plunge and ordered the fluke micoscanner 2
It is great for testing cat 6 circuits.
It saves me from embarrassment afterwards if it doesn't work when someone plugs in.
Me and an IT girl spent hours one day with me on my knees in a comms room trying to sort out a dodgy connection.
All I had was a fluke 179 and a patch lead cut in half and stripped back. I was doing continuity tests. The whole thing was horrendous.
She wasn't a looker then.......
She actually is pretty decent. You definitely would. But the novelty wears off pretty quickly. I was getting a stiff neck and nothing else :confused:
All joking aside, she is a nice girl, and we often have to look after each other, she got me a new laptop a few months ago.
You really need to see some of the stuff that I had to sort out, this one was tame on a security switch/cabling upgrade in a company the dealt heavily with on line payments.
[ElectriciansForums.net] Cat 6 connections by a sparky
All too common poor work like that. These are pictures from one of the UKs leading ISPs:
Lots of fibre in there, I used to install dealing rooms, fresh installs where nice but dealing with some places after a few years, jeeeez and don't ask about Krone Frames at some of the places I had to support......
I do like a good Krone frame not to mention the odd cheeky DDF frame full of type 43s and U links...
Reply to Cat 6 connections by a sparky in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Recommended Sponsor News
Hi everyone,
