Good afternoon
I have a furnace blower from USA that I’m using as part of a filter box, the blower is a 115v and 1.35amp
DAYTON Rectangular Permanent Split Capacitor OEM Specialty Blower, Flange: Yes, Wheel Dia: 6-3/16", 115VAC - 1TDR7|1TDR7 - Grainger - https://m.grainger.com/mobile/product/DAYTON-Rectangular-Permanent-Split-1TDR7
My understanding is that I need to connect a plug to the blower (U.K. or must it be us style?) and then I need to connect the blower to a step up transformer which in turn gets plugged into my U.K. socket.....
200/500/1000/2000W UK-US US-UK Step Up/Down Voltage Converter Power Transformer | eBay - https://www.ebay.co.uk/itm/200-500-1000-2000W-UK-US-US-UK-Step-Up-Down-Voltage-Converter-Power-Transformer/182829729494?hash=item2a918046d6:m:mb2OgqPght0_pFmexPv5MBA&var=690133097153&_trkparms=gclientid%3DNncHuwFKU1fmqR5EoBL2uR-a9g8IcUpPUhesyOcX_xTHpPd4wCCk2VTA1a97k3y3&_trksid=p2489528.m4335.l8656
Would this transformer work? Say the 500w model? I’m also a bit confused about the transformers amperage which is rated at 0.8, is that enough for the blower?
I’m also having a hard time as to why I can’t find a 240v to 115v transformer? Does that 5v make much difference?
If I may also get some info on the wiring, their is a capacitor their, do I do anything with it? And the wiring, black goes to our brown, white to our blue and my earth gets screwed under the screw by the little green sticker(earth sign?)?
Any help would be appreciated
