Dimmer switch help! Not turning brightness down low | on ElectriciansForums
Guest viewing is limited
Discuss Dimmer switch help! Not turning brightness down low in the UK Electrical Forum area at ElectriciansForums.net
Glasgkw
ive just installed 13 4w LAP downlights with are controlled by a dimmer switch. When I turn the switch on I can turn the brightness up no problem but when put it down low they still seem bright, could this be a switch issue? Thanks in advance
[ElectriciansForums.net] Dimmer switch help! Not turning brightness down low
Yes it was controlling 2 of the lights above, cheers
Reply to Dimmer switch help! Not turning brightness down low in the UK Electrical Forum area at ElectriciansForums.net
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
I'd start by doing the usual supply impedance tests followed by N-E voltage with the installation under some load. Also visually inspect and...
Recommended Sponsor News
Hi everyone,
