LAP Carp - who designs this stuff? | on ElectriciansForums
Guest viewing is limited
Discuss LAP Carp - who designs this stuff? in the UK Electrical Forum area at ElectriciansForums.net
Exeter - a glorious place to live!
[ElectriciansForums.net] LAP Carp - who designs this stuff?
Before and after - room to loop through now!
And I see there's plenty of room for a fixing screw to snag a live cable... What sort of screw are you using? A nice silver countersunk would look great on the front of that.
Assuming there's not a hidden bracket for this fitting
i had fitted some the other day ,and i did not have problem .so what are you crieing about ,was it to hard for you .and now you have altered the tails for the fitting ,where are the cloth heat cover you took off .or you sending them back to china in a letter say not needed ,willy fixit ok .
Just making a point really - it was a squeeze and a bit unnecessary imho. And working off steps in the cold it was a lot easier to only have to push in the solid cores.
Heat covers were only on 3 wires and theres no way these things will get remotely warm so I reckon they were OTT. The PIRs are probably bought in items by LAP and come with them in case they're shoved in next to a 1000W halogen lamp!
maybe I'm nit picking the people designing them light fitting put those heat covers on for reason
why don't you send the company that make them a letter tell the designer the fitting are c77P.and they will give you the answer.
Reply to LAP Carp - who designs this stuff? in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
I would think that if they are apartments, and not something like uni halls with private bedroom and communal facilities, then each one would be...
Recommended Sponsor News
Hi everyone,
