Before and after - room to loop through now!
Discuss LAP Carp - who designs this stuff? in the UK Electrical Forum area at ElectriciansForums.net
i had fitted some the other day ,and i did not have problem .so what are you crieing about ,was it to hard for you .and now you have altered the tails for the fitting ,where are the cloth heat cover you took off .or you sending them back to china in a letter say not needed ,willy fixit ok .
maybe I'm nit picking the people designing them light fitting put those heat covers on for reasonHeat covers were only on 3 wires and theres no way these things will get remotely warm so I reckon they were OTT. The PIRs are probably bought in items by LAP and come with them in case they're shoved in next to a 1000W halogen lamp!
Caen U neck oop a tamplet thet weee caen us e to sand t2 that manefecturaer.maybe I'm nit picking the people designing them light fitting put those heat covers on for reason
why don't you send the company that make them a letter tell the designer the fitting are c77P.and they will give you the answer.
Something about this post just tickled me. Now I’m rolling around with laughterCaen U neck oop a tamplet thet weee caen us e to sand t2 that manefecturaer.
Ta ;o))))
One problem I see is the new set up isn't designed to take three conductors in the push side (neutral)
No heat proof sleeve on the other wires!!! Same current !
Reply to LAP Carp - who designs this stuff? in the UK Electrical Forum area at ElectriciansForums.net
