electrical installation on a floating dwelling | on ElectriciansForums
Guest viewing is limited
Discuss electrical installation on a floating dwelling in the UK Electrical Forum area at ElectriciansForums.net
Andy78
Mentor
Kingston upon Hull
I really need some help in a project I have become involved in wiring a lived on boat. It's something I have not done before or anything remotely similar so I'm well out of my comfort and confidence zone.
I'm really struggling finding a definite guide as to the correct regulations I need to be following or even any best practice guides. If anyone can offer any experienced advice in this field I would be most grateful, even a finger pointing in the right direction would be great.
I'll refrain from posting detailed info about the job until an experienced mind pops along as it might be a bit much.
The installation on the boat is nothing special- just to bs7671
As long as it’s connected to a supply conforming to section 709, marinas and similar locations.
Section 709 shows the supply cable on the boat, and special regards to metal parts in contact with water.
I think you have to carefull that you dont connect the metal hull to earth as it can course corosion i think , sorry to be vage on it but i remember it being talked about back when i was in college , worth looking into.
Ok, bit more info.
Won't be connected to a shore hook up, but will have the capability to be.
Boat is a steel hull
Will be powered via solar panels charging 12V batteries.
12V and/or 230V (via inverter) will be used for lighting and power with a 24V system for the engine room solely for the engine start operation.
Yes, have heard about galvanic isolators needed when hooked up to shore supplies, need to research this a bit more....
If its a canal barge, you take it on the right hand side, and not the left when "driving" it along.
I took a family members boat along the Union Canal in Edinburgh from the centre out to the bypass. There's an aquaduct crosses the 4 lanes of the bypass... my kids on the bow waving at the drivers below.
[ElectriciansForums.net] electrical installation on a floating dwelling
Only thing we had to watch out for was the university canoe club.
The Union Canal needs a good dredging. One time I wasn't there, the boat picked up an old mattress from the bottom and wrecked the propellers. A week later another boat brought up a corpse. :eek:
Reply to electrical installation on a floating dwelling in the UK Electrical Forum area at ElectriciansForums.net
Hi I need help and advice on knowing minimum cross sectional area CSA TN earthing conductor size please
Recommended Sponsor News
Hi everyone,
