Programmer live in and live out reversed | on ElectriciansForums
Discuss Programmer live in and live out reversed in the Central Heating Systems area at ElectriciansForums.net
xnescx
Newcastle
hey, I’m a gas safe plumber and today I came across a programmer wired backwards basically, the live in and live out mixed up yet the boiler was still functioning without issue, calling for heat as should.
Anyone care to educate me on the issue with the above or does it not really matter?
So normally open and normally closed switch wires where mixed up,
L and N feed was correct, just the switch wires not, I went to replace the programmer for a more user friendly one for my customer hence noticing
No way how did that happen ,are you saying the neutral was in the line and the line was in the neutral reversed polarity.
Hi - the N is connected to Earth at the supply transformer and the house copper pipework is also bonded to the house's main earth terminal. So any reversals of L and N within the boiler, programmer or zone valves would normally result in it not working, perhaps with a bang. If I've understood correctly, since it was working, the system was likely configured as "volt free" like the diagram, where it's job is to provide a time/temperature controlled connection across the boiler start terminals (B and A here).
[ElectriciansForums.net] Programmer live in and live out reversed
So in effect,not wired to conventional pattern,but no risk or harm done. :rolleyes:
This would depend on the type of C -N/O-N/C switching fitted,where if there were any additions,such as tell-tale LED's,or other feature,the position of the L and S/L would be crucial.
Reply to Programmer live in and live out reversed in the Central Heating Systems area at ElectriciansForums.net
Take them back. If enough people do, then perhaps the manufacturers would stop designing and supplying such badly designed rubbish. If this...
Hi Gingerrubix, The fact that your previous Tenant replaced a faulty socket plate which he used for an external EV, raises an eyebrow. Also your...
Think all electricians will/have received a belt in their time. Doesn't matter how many time you read something like this, and are told to L-N N-E...
    • Informative
    • Thanks
Thanks Yes its wired to the load side of an isolator to provide local isolation and isolator is permanently on, only other connections to the load...
