Bell 801 Entry Phone System Wiring help | on ElectriciansForums
Discuss Bell 801 Entry Phone System Wiring help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hertfordshire
Morning all,
Hope you’re all well.
I have replaced my entry phone system for the same one just a fresher one as have been decorating.
However, the dummy I am, I didn’t take a pic of where the wires go and now I’m lost. I’ve got the sound working when someone pushes the buzzer downstairs, but none of the other features work.
See attached image of the system.
Hope you guys can help.
Best, Greg
[ElectriciansForums.net] Bell 801 Entry Phone System Wiring help
As asked is this a stand-alone system? I think the best way with looking at the instructions that SparkyChick has posted you will now need to see what the connections are at the outdoor unit if it is a stand-alone system.
Reply to Bell 801 Entry Phone System Wiring help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This is really helpful. Does anyone know of a way to wire this in in parallel but use a wifi enabled switch?
I have removed and looked at the old entry phone. It has 6 wires. Blue plus blue and white. Green plus green and white. Orange plus orange and...
Hi Gingerrubix, The fact that your previous Tenant replaced a faulty socket plate which he used for an external EV, raises an eyebrow. Also your...
I have seen less than Screwfix, but £20 sounds a very good deal indeed.
5K
I've always installed Texecom Premier Elite panels and would highly recommend them. Cant go wrong with Hikvision cameras either, haven't...
