work in progrees in Micro Brewery. | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss work in progrees in Micro Brewery. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
s title. soon be up and brewing.
[ElectriciansForums.net] work in progrees in Micro Brewery.
@SWD.youtry putting in nice bends in XLPE at 0 deg. celcius.
@ ant. cables to loads are 6.0mm silicon flex. glanded into isolators with stuffing glands, cleated to provide extra strain relief.
I think you are missing the important bit here which is getting the brewery up and running. Appearance can be worked on later ;)
nail on head. it's ready to go. bit of tidying up to do after xmas, but will tie that in with some extra work he wants doing. he has to plumb in the pumps which are ready wired, then he's brewing.
Tel you'll find as I've noticed that the most vociferous critics never,ever post up any photos of work they've done, I rest my case.
However it's a shame that one of those side by side isolators is 5mm higher than the other. :p:D:eek:
they are not out.it's called parallax. makes them seem out.
Reply to work in progrees in Micro Brewery. in the UK Electrical Forum area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
Bugger that. They end up in whatever position they want :D
    • Informative
Recommended Sponsor News
Hi everyone,
