Help wiring cooker hood for cafe | on ElectriciansForums
Discuss Help wiring cooker hood for cafe in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
London
Hello I’m confused about the amount of wires for a cooker hood that need fitting into a speed control switch and then into fused spur. I’ll attach some photos but can you guys please help me on how to wire this?
[ElectriciansForums.net] Help wiring cooker hood for cafe
eliminating the gn/y as E, the you kave 3 Ls and a N. these 3 Ls will be 3 speeds. trial and error or bang.do you feel lucky punk? :p:p:p.
Well do you? go on make my day, this is a pair of Klein Linesman pliers, the most powerful pliers in the world.
If the capacitor is integral to the motor, then the MI's for a similar model from the same series confirm that there are four lines for four speeds, plus N & E, but it doesn't say which colour is which speed. I would take a few resistance readings to confirm that the blue wire really is N, and test them, although you may well also be able to confirm which L is which speed as they will probably be in order of resistance to N.
If there is no capacitor on the motor itself, then it will need to be in the terminal box and the above does not apply as one lead will be for the capacitor winding.
Identifying the correct terminals on the switch is a matter of 2 mins with a continuity tester. If you find three separate N/O contacts, obviously connect one end of each of them to line and the other end to one of the speeds. Park the line for the unused speed.
The datasheet gives the physical pinout of the connector, if one is fitted, which would allow you to confirm the functions of the colours. If yours does not have the connector, I think the sequence is as follows (by looking at the matching cable assembly)
1 / white
2 / red
3 / grey
4 / black
N / blue
1 / white
2 / red
3 / grey
4 / black
N / blue
Thanks, so when it comes to wiring the switch that’s what’s confusing, where is my twin and earth going and all 6 wires? I can’t get a wiring diagram of the switch anywhere
Reply to Help wiring cooker hood for cafe in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Could you not make something? For example a thin metal sheet (aluminium for ease of working) a bit bigger than the hole (say 180 x 120 mm), with a...
allowing for diversity a 32 amp supply will be fine for them both, but remember, the cable needs to be adequate to cope with a load on up to that...
  • Locked
See this thread. https://www.electriciansforums.net/threads/fitting-new-cooker-hood.209819/
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
How about one of these ? No supply needed and has the benefit of having an array of different knocks for all types of moods.
