Help wiring cooker hood for cafe | Page 2 | on ElectriciansForums
Discuss Help wiring cooker hood for cafe in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If the capacitor is integral to the motor, then the MI's for a similar model from the same series confirm that there are four lines for four speeds, plus N & E, but it doesn't say which colour is which speed. I would take a few resistance readings to confirm that the blue wire really is N, and test them, although you may well also be able to confirm which L is which speed as they will probably be in order of resistance to N.
If there is no capacitor on the motor itself, then it will need to be in the terminal box and the above does not apply as one lead will be for the capacitor winding.
Identifying the correct terminals on the switch is a matter of 2 mins with a continuity tester. If you find three separate N/O contacts, obviously connect one end of each of them to line and the other end to one of the speeds. Park the line for the unused speed.
The datasheet gives the physical pinout of the connector, if one is fitted, which would allow you to confirm the functions of the colours. If yours does not have the connector, I think the sequence is as follows (by looking at the matching cable assembly)
1 / white
2 / red
3 / grey
4 / black
N / blue
1 / white
2 / red
3 / grey
4 / black
N / blue
Thanks, so when it comes to wiring the switch that’s what’s confusing, where is my twin and earth going and all 6 wires? I can’t get a wiring diagram of the switch anywhere
I think we've sussed the fan - the control switch selects one of four lines for the speed required. What the OP is stuck on now is how to wire a 4-position camswitch for 1P4W.
With the switch being marked 0-3, one speed (e.g. minimum) will have to be unused. It is likely to be something like:
White (speed 1) park in a Wago.
Red (speed 2) to switch terminal 1
Grey (speed 3) to switch terminal 3
Black (speed 4) to switch terminal 5
Blue (N) to incoming supply N.
Switch terminal 2 to incoming supply L
If they are not internally linked, it will be necessary to link terminals 2, 4 & 6 to extend the line to the other two contact sets.
Please check all of this with your meter before connecting up!!
Reply to Help wiring cooker hood for cafe in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And metal backboxes partly full of pink plaster smacks of lazy DIYers, or equally lazy professional sparkies.
Could you not make something? For example a thin metal sheet (aluminium for ease of working) a bit bigger than the hole (say 180 x 120 mm), with a...
