What are the best grips/ water pump pliers for price and quality??
Discuss Best water pump pliers in the Electrical Tools and Products area at ElectriciansForums.net
Cheers and yeah will be using for armoured glands and tightening couplers bushes etc. Im torn between bahco and knipex
who cares after the condom is fitted?
The Bahco ones I use have a taper to the jaws.so many cases where you can't get any make of grips in to tighten locknuts, due to lack of clearance. that's where the hammer and cheap screwdriver is king.
Wedging something in between the nut and the obstruction usually does it for me.the problem is when the gland is so close to the structure of the enclosure. on some i've even had problems getting a locknut on, knockout being so close to the back of the box. even had to use a lock ring on several occasions,
so that's your excuse for the slack halliards, then.Bahco for me, every time...they were so impressive that a plumber working on my house nicked them...bas***d!
Reply to Best water pump pliers in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
