Wiring a led tombstone | on ElectriciansForums
Discuss Wiring a led tombstone in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Barbados
How do i wire a led tombstone for a single bulb led fixture. The tombstone have space for 4 wires. Does it matter which I put the wires into?
Reply to Wiring a led tombstone in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, If you are looking for reliable EV chargers, check out our top-rated selection at E2GO! ⚡ Please note that all EV Chargers and...
    • Friendly
I would try to avoid connections outside of the fittings. Can you not “ loop in and out” of the fixtures
Loose neutral somewhere… possibly at panel or at the last light before it goes to panel. You say you’re getting power through the switch and up...
