Vphase VX1 problem | on ElectriciansForums
Discuss Vphase VX1 problem in the UK Electrical Forum area at ElectriciansForums.net
Sion1234
Surrey
Hi all.
I'm sorry if this is in the wrong section of the forum, I'm just in need of help.
Moved into a house about 6 months ago. We have solar panels with the box etc under the stairs, but the previous owner has also had a Vphase VX1 voltage optimiser installed (I'm guessing as part of the solar package) as its wired into the solar box as well as the electricity board.
However, yesterday the vphase box started making an intermittent clicking noise (ever 30 seconds roughly) like it's tripping? . I have turned the electricity off and back on to see if this would reset it but no luck. The only time it will stop clicking is when a high amount of electricity is being used, for example when I boil the kettle.. It doesn't click. As soon as the kettle boils... It begins to click again.
Anyone have any idea on what is happening and how I can resolve it?
Kind regards
Thanks for the reply. This won't effect how my solar panel systems works I take it? Sorry if that's a dumb question I just have no idea on all of this. I'm considering just getting EDF to fit me a smart meter.
It’s not a dumb question,
As above, get an electrician in to remove the voltage optimiser, they were sold to people with the promise of reducing bills but in my opinion you need an unusual set of circumstances for it to be of any use.
It could also be detrimental to the efficiency of the solar system itself.
You will save more in a year by replacing 1 old style “light bulb” with an LED equivalent than you are likely to with your voltage optimiser.
That's good to know. It's like a maze looking at the layout of it all under the stairs haha. I've added some pics of it all, the vphase is the one with the green led on and fuse box is above it to the left.
Do you think this will be a big and pricey job removing the it?
Don't that either. They are another con which will cost you money, not save it.
Thanks for the advice, someone else did say that too me as well so that backs that up
I've read that these vphase box's wired in with a solar PV system stop the inverter cutting out or something when the voltage produces becomes too much, so it regulates the voltage coming back in. Mine is wired in to the pv system but would it still be OK to have it removed?
Why will a smart meter cost money?
because thee supplier can alter the tariff at will. so you get cheap leccy when you're out and not using it, , and expensive leccy when you're showering/cooking/ growing illegal plants.
They have to be manufactured and sold to the suppliers and fitted. The suppliers pass this cost to all of us through increased bills.
The very minimum "visible" extra costs are the batteries you have to buy for the remote unit every now and then.
But look at it this way. If every one had smart meters, and every one saved money someone somewhere must be losing out, and that would appear to be the suppliers. They then have two choices, go under or increase everyones bills.
Do you know of a supplier or have an example of a supplier who does this? My supplier (Octopus Energy) charges me 14.67p/kWh + VAT no matter when I use it.
Bulb has a smart meter experimental tariff:
1600 -1900 hrs (Dinner cooking time) 29.75p per kWh
2300-0700 hrs (overnight) 7.45p per kWh
other times 12.19p per kWh.
Standing charge 20.44p per day.
This is in SE London, other areas may vary slightly.
Reply to Vphase VX1 problem in the UK Electrical Forum area at ElectriciansForums.net
