Discuss Why would a DNO do this? in the UK Electrical Forum area at ElectriciansForums.net
sleeving. from the spell check gestapo.On further inspection I don’t think DNO fitted that isolator either.
They are much better than that. Sleaving is not fully enclosed on a couple of the tails on either side from what I can see.
As for the seals anyone can buy them.
pease explain in layman terms.I'm in fixing a re-wire by a handy man
what not even tempted,on the block and isolator its sealed with a xxxxxx.I'm going to remove it, don't even need to break the seals as it's on the consumer side of the isolator, just thought I'd get some others thoughts on it
The isolator is upside down.
Definitely dno installation then!The isolator is upside down.
Yeah, in the property upstairs too!The isolator is upside down.
Reply to Why would a DNO do this? in the UK Electrical Forum area at ElectriciansForums.net
