Fitting SPD as standard | on ElectriciansForums
Discuss Fitting SPD as standard in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Evening all
Is anyone fitting surge as standard in domestic property’s?
We are based down in Dorset which has 3 different flash density’s!!
So I always base is on worse case with most of our stuff being in urban areas and always unable to confirm length of supply cable! My calc is usually;
Urban 850/(1x0.50) = 1700 No SPD
Rural 85/(1X0.50) = 170 SPD
Thoughts?
Hi - I don’t do that many domestic boards but I’ve been pricing SPD in now. I have recently fitted 3 Wylex flex S boards (NM1206FLEXS with 12 ways left after iso and SPD). These come prefitted with SPD and cabling and are nice :) .
What's the difference in cost to a non factory fitted spd unit.
I've been fitting the Hager version with pre-wired SPD, good quality unit once you tidy up the wiring to the SPD and neutral bars! Customer requested dual RCD as it was the cheaper option but usually I would try and go for full rcbo.
[ElectriciansForums.net] Fitting SPD as standard
Reply to Fitting SPD as standard in the UK Electrical Forum area at ElectriciansForums.net
