External junction boxes | Page 2 | on ElectriciansForums
Discuss External junction boxes in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Quite like these,for various connections,hate the connectors inside though.
Wondering would you use compression glands on entry for flexes or pierce through the sealing membrane../neoprene to seal/hold the cable.
[ElectriciansForums.net] External junction boxes
Earthing nuts do not fit them you are supposed to use these neater than lashing a banjo on the outside.
This is the correct item you use for those types of boxes as the thread is not long enough to bite the Parana earthnut. Wiska is a manufacturer they also do a smoothed faced adaptable box that you drill and the wall thickness is such that you can fit an earthnut around the gland thread.
Always use glands with them and either strip connectors or wagos depending on how many I've to terminate inside.
Never use the connectors inside, although the brass part can be used as a nut for some outside lights if you drop and lose it lol just touch up with a black marker.
Reply to External junction boxes in the UK Electrical Forum area at ElectriciansForums.net
Use wago connectors instead, much easier and safer I think
If it's underground I've always favoured SWA with good old fashioned resin joints. I would make a 3 way resin joint below ground, no enclosure...
