Was called out to a site where an employee has recieved an electric shock when turning on a light.
When I isolated and removed the switch the cause was immediately apparent.
It was a metal surface box and mettal clad switch, the back box had been drilled through the back for a 20mm conduit but never used, favouring a top entry using condit.
Basically the rear entry hole had left a nasty burr which over 30ish years has slowly cut into the line conductor until yeasterday when someone operated the switch and wallop.
The guy had a lightly singed finger and attended hopital for a check up but was otherwise ok.
Fortunately the circuit had been put on an RCBO due to an addition, although not necessary at the time.
Amazing how such an issue can sit there for so long before zapping someone.
