Need help with wiring a celing fan | on ElectriciansForums
Discuss Need help with wiring a celing fan in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Djiplay
London
Been up since 5am trying to figure this out. Can anykne give me some advice on what colour goes where?
[ElectriciansForums.net] Need help with wiring a celing fan [ElectriciansForums.net] Need help with wiring a celing fan
Hi - Please make sure you’ve turned off the power to that circuit (if you’ve a tester) or the whole house if you’re doing a “best guess”. I think the dark grey cable probably goes to the smoke alarm, then the cable with black sleeved red goes to the light switch and the other is the incoming feed. Hope that helps :) .
red,red and brown into a choc block. black and blue into N for fan. black with red sleeve into fan L. all earths together into E. earth flylead tagged onto fan body tag.
Advice for next time:
Take a photo of connections of the old fitting before you take it down. Note which ones go to either side of the lamp itself.
That's a switchwire, and a nuatral. All the green and yellows are earths. Anything left is a permanent live and will hurt if touched, even with the switch off.
Follow Wilkos advice on isolation and Telectrix on connection
i can see a smoke detector near the new light and the omanisation of the colours brown and blue , if the op does not get write he could be black and blue .i agree with the lads if you are out of your comfort zone pick uk the phone.
Sorry for late reply just got back from work. It was rose wiring but the extra grey flattish wire was connected also which i think is the smoke alarm. Now from the instructions it makes no sense to me.
[ElectriciansForums.net] Need help with wiring a celing fan [ElectriciansForums.net] Need help with wiring a celing fan [ElectriciansForums.net] Need help with wiring a celing fan [ElectriciansForums.net] Need help with wiring a celing fan [ElectriciansForums.net] Need help with wiring a celing fan [ElectriciansForums.net] Need help with wiring a celing fan
This is what it was
[automerge]1568636623[/automerge]
[automerge]1568636656[/automerge]
[automerge]1568636751[/automerge]
I was half asleep earlier. Iv tried wiring it but probably done it wrong. I am a fast learner but i need to learn
  • [ElectriciansForums.net] Need help with wiring a celing fan
read post #4 and start over. those reds should not connect to the fan terminals.
Ok will do.
[automerge]1568638269[/automerge]
[automerge]1568638293[/automerge]
Isnthat correct. I will put the eart in after
Well that is confusing. There are 2 switchwires in the fitting... one for fan, one for light... but they only give one L terminal.
Suggesting you put both into L....
or you could have light through the switch and fan on perm live... controlled via the fittings pull switch.
Also make sure you have a good fixing into a wood joist. Those things are heavy.... plasterboard fixings won’t hold it for long.
Re your last photo.
No.... replace the bare connector from the ceiling rose with an insulated block terminal or a WAGO. That will go live, touch the metal fan base and trip a breaker, or worse!
Please ask an electrician now
Re your last photo.
That block is just temporary. In the room there is a light switch with 3 switches. 1 for the conservatory 1 for the room and the other i cant remember... maybe outside. Its a new home. Also there is a smoke alarm im sure its that big grey cable connecting to it.
I think you would be wise getting an electrician in. Full marks for trying, but I think this is probably out if your depth. No offence intended - I'm all for people doing things theirselves.
if you’re following instructions from post #4, then you’re on the right track. The brown and blue in the grey cable are new colours replacing the red and black of the original house wiring. The smoke detector requires a permanent live and neutral.
The black with red tape is the switchwire (live when switch is on)
Everything else is either permanent live, neutral or earth.
Please replace that bare copper terminal... I’m having heart palpitations!
Reply to Need help with wiring a celing fan in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
I guess the easiest way would be to run a supply from ignition /aux via a relay that drops the supply when the lights are on.
