Need help with wiring a celing fan | Page 2 | on ElectriciansForums
Discuss Need help with wiring a celing fan in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
first make sure circuit is isolated. if necessary switch the whole board off. the 2 reds and the brown to the smoke go in a single connector with nothing else connected to them. the black with red sleeve goes to fan L. the blue and plain black go to fan N. then just the earths.
The lights are off and my phones dying so no flash lol. It works but i have a new problem. Its in reverse so the ceiling is getting air....
Most of these fans come with a switch on the side to reverse the fan.
So it’s either a cooling fan, blowing down, or an air recirculating fan.
Read the instructions again.
100 percent correct. Im so glad i found this forum. Thank you all that have helped. I would recommend this forum to everyone. Im a total noob in electr9nics yet i could build a pc from a calculator and a bit of wood lol. Thank you all so much
Someone’s already done that and called it a raspberry pi
Reply to Need help with wiring a celing fan in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
Which begs the question, where does the second brown wire come from?
