Hello, I've found an old motor originally designed for operating jealousies.
Could you help me read and better understand the following schematic?
As far as I understand, it is a single phase induction motor, there is 47 uF capacitor connected to it in order to start.
There are 3 contacts marked 1, 2, 3 + PE. There is also a switch button.
What would be the correct way to wire 1, 2, 3 contacts? What is the purpose of the switch button? (change of rotation direction?)
I measured resistance between these:
12 - 121.7 ohm
23 - 242 ohhm (both windings?)
13 - 120.5 ohm
Thank you
12 - 121.7 ohm
13 - 120.5 ohm
Thank you
